Results 1 to 9 of 9
    Dec 2008
    greece
    47
    227
    r13b1 temperature pressure chart
    I need the R13B1 temperature-pressure chart.Can anybody help me?
    Oct 2007
    manchester
    5,639
    45
    Re: r13b1 temperature pressure chart
    danfoss kool app has it
    Dec 2008
    greece
    47
    227
    thanks for reply..I do not have it..anything in pdf?
    Oct 2007
    manchester
    5,639
    45
    1 step ahead of you sir- copy and paste in ur search engine
    detector-cooling.web.cern.ch/Detector.../Refr.ptchart2.pdf
    Dec 2008
    greece
    47
    227
    Very good install monkey..If you find something more detailed and in Celsious degrees please send.Thanks anyway.
    11,024
    I do hope that you are not actually using that gas are you?
    Dec 2008
    greece
    47
    227
    No Brian.I found an old machine tha used that gas.I propably will retrofiit to another refrigerant,but i would like the pressure-temperature chart,to make it.
    Oct 2007
    manchester
    5,639
    45
    http://www.mediafire.com/view/?mm1l6rs1hv36vp3
    isceon 89 is a replacement-
    as for a simplified pt chart
    0psig -58.1c
    10psig -46.5c
    20psig -38.1c
    30psig -31.4c
    40psig -25.7c
    50psig -20.8c
    60psig -16.4c
    70psig -12.4c
    80psig -8.8c
    90psig -5.4c
    100psig -2.2c
    150psig 11c
    200psig 21.8c
    250psig 30.9c
    300psig 38.9c
    350psig 46.1c
    Dec 2008
    greece
    47
    227
    very specific install monkey.thank you very much.
