Thread: Bosch F/F KGN36 Evap removal
24-09-2012, 03:55 PM #1
Hi Guys got a Bosch enr KGN36X42/07 I wanted to check the defrost element & stats I removed the screws & slid the whole unit forward about 3-4 inches then lost my nerve is this the way to remove it.also is it poss to put it into forced defrost mode. Thanks Mack
24-09-2012, 06:13 PM #2
Re: Bosch F/F KGN36 Evap removal
It not possible to remove the evaporator without de gassing the sytstem first .it's part of the sealed refigeration sysyem charged and under pressure,elements.sensors and stats are all plug in/connectors and can be disconnected either in the freezer compartment or at the controls in order to do a check with a suitable meter.
“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
06-11-2012, 06:59 AM #3
It is preferred to remove the evaporator to avoid collision.For More information please visit www(dot)pandorasoem(dot)com.
06-11-2012, 08:20 AM #4
