Results 1 to 2 of 2
Thread: Trane RTAD 125
    Jun 2010
    Wales
    45
    Trane RTAD 125
    Hello guys,
    quick question, any of you had any problems with these chillers regarding leaks?
    Especially around the condenser/ discharge pipes
    Carrying out PPM on this chiller i've found a lot of oil around the condenser and passes into the condenser, & this is on both circuits with two separate condensers!
    The customer wasn't too bothered mind with the remark '' Don't worry about it, as long as are Air plant is hitting set point, we don't care'' LOL! Not for long
    Nov 2008
    136
    Re: Trane RTAD 125
    Hi lukey
    Doesnt look good, does this chiller short cycle, the expansion and contraction of the copper through the metal ends can cause friction and the copper will wear through causing leaks. lucky you dont have a carbon tax on refrigerant like we do in aus.
