Results 1 to 1 of 1
21-09-2012, 08:48 AM #1
converted a dehumidifier 2 a heatpump
it has the compressor'Fan and a hot 10 inch by 10 inch radiator inside the house to dissipate heat.outside the house and through a window is a 10 inch by 10 inch radiator which collects heat from the cold outdoorsand has a fan and casing well So that it pulls the airthrough the radiator. This was the most convenient way to set this thing up. It is a dehumidifier with ***** 12 in it which I split the cold and hot radiators so to place 1 radiator indoor and 1 outdoor and make the heat pump.
Q-how hot can I get hottest part of the compressor and system safely?I am anticipating and permanent ice build up with the temperature drops and stays below freezing itand defrosting the outer radiator by overheating the indoor radiator
