    Apr 2012
    Foshan,Guangdong
    37
    7
    inside cylinder pressure of xenon gas
    HI guys,
    Currently I met a tough question. I want to use a 4L aluminum cylinder to fill 200L xenon gas. But I want to know how to calculate the inside cylinder pressure of the xenon gas at 273K and 288K.
    xenon gas is a high liquefied gas, and its compressibility factor varies significantly when pressure and temperature changes.
    Please help me figure out this, thanks in advance.
    11,025
    Apr 2012
    Foshan,Guangdong
    37
    7
    Re: inside cylinder pressure of xenon gas
    Thank you for your kind help. I want to fill 200 litre xenon gas into 4 litre cylinder.
    The xenon gas is gonna be gas and liquid in the cylinder. The xenon gas is a high pressure liquefied gas, which differs from the permanent gas as the latter one is stable in the cylinder. For instance, helium gas, I will get 150 bar if I fill 6 cubic meter into 40 litre cylinder according to the Ideal Gas Law. But it seems to be difficult for me to calculate the pressure once it's a high pressure liquefied gas.
    Oct 2007
    sweden
    93
    Xenon
    critical temperature 16.584 degree C (above this you not have any liquid part of Xenon inside cylinder on any pressure)
    critical pressure 5.84 MPa
    critical density 1.099 kg/liter
    -30 degree C at total density at 1.099 kg/liter, pressure 2.03 MPa, vapor density 174.85 gram/liter , liquid density 2323.8 gram/liter
    -20 degree C at total density at 1.099 kg/liter, pressure 2.62 MPa, vapor density 231.3 gram/liter , liquid density 2201 gram/liter
    -10 degree C at total density at 1.099 kg/liter, pressure 3.31 MPa, vapor density 306.9 gram/liter , liquid density 2070 gram/liter
    0 degree C at total density at 1.099 kg/liter, pressure 4.14 MPa, vapor density 414.7 gram/liter , liquid density 1910.1 gram/liter
    10 degree C at total density at 1.099 kg/liter, pressure 5.11 MPa, vapor density 597.0 gram/liter , liquid density 1676.7 gram/liter
    16.584 degree C at total density at 1.099 kg/liter, pressure 5.84 MPa, vapor density 1099 gram/liter , liquid density 1099 gram/liter
    20 degree C at total density at 1.099 kg/liter, pressure 6.25 MPa, vapor density 1099 gram/liter , liquid density: overheated
    30 degree C at total density at 1.099 kg/liter, pressure 7.45 MPa, vapor density 1099 gram/liter , liquid density: overheated
    40 degree C at total density at 1.099 kg/liter, pressure 8.66 MPa, vapor density 1099 gram/liter , liquid density: overheated
    50 degree C at total density at 1.099 kg/liter, pressure 9.87 MPa, vapor density 1099 gram/liter , liquid density: overheated
    60 degree C at total density at 1.099 kg/liter, pressure 11.09 MPa, vapor density 1099 gram/liter , liquid density: overheated
    70 degree C at total density at 1.099 kg/liter, pressure 12.3 MPa, vapor density 1099 gram/liter , liquid density: overheated
    80 degree C at total density at 1.099 kg/liter, pressure 13.54 MPa, vapor density 1099 gram/liter , liquid density: overheated
    90 degree C at total density at 1.099 kg/liter, pressure 14.76 MPa, vapor density 1099 gram/liter , liquid density: overheated
    100 degree C at total density at 1.099 kg/liter, pressure 15.98 MPa, vapor density 1099 gram/liter , liquid density: overheated
    if you mistakingly fill cylinder on top with liquid xenon at +10 degree (density 1677 gram/liter), seal it, and later time, heating up cylinder to 60 degree C (stored inside VAN in hot sun for example) - you have pressure inside cylinder about 17.6 MPa (175 bar above atmospheric pressure)
    Data take from Nist Refprop
    Apr 2012
    Foshan,Guangdong
    37
    7
    Thanks you, xxargs.
