Thread: solder fell into torch tip
30-12-2005, 05:32 PM #1
I was about to install plumbing for an icemaker when I noticed that some solder fell into the torch tip from a previous use. Has anyone else experienced this problem? What's the solution?
30-12-2005, 11:10 PM #2
Re: solder fell into torch tip
Do you have another source of heat? If yes then hold blocked tip with open end down and apply heat to soften solder.
Second option, get a drill bit to match the size of the torch opening and drill out the solder.Brian - Newton Abbot, Devon, UK
01-01-2006, 08:57 PM #3
Thanks. I just bought another torch, melted the solder out, and got the install done.
BTW, compression fittings are no good. I had one connection leak twice, and the two I currently have installed are leaking very slowly. What's the solution?
01-01-2006, 10:47 PM #4
Originally Posted by star882
If it's refrigerant then you shouldn't be using compression fittings.
One problem with compression fittings is that people tend to overtighten them which damages the olives and seats.Brian - Newton Abbot, Devon, UK
01-01-2006, 11:07 PM #5
The only two types of compression fittings I am aware of are; those for water which should should not be used, or those for hydraulic tubing. The hydraulic fittings work OK so long as you use the correct ferrules for the tubing.
01-01-2006, 11:53 PM #6
Originally Posted by Brian_UK
Oh, are flare fittings any better at sealing the connection?
Torch
By Peter_1 in forum IndustrialReplies: 7Last Post: 17-07-2009, 04:53 PM -
SnAg solder (Stay-Brite): which fluxes are suitable?
By DaBit in forum Technical SpeculationsReplies: 3Last Post: 14-08-2005, 08:29 PM -
solder V Flare Driers
By Latte in forum Technical DiscussionsReplies: 45Last Post: 23-05-2004, 09:22 AM -
the best torch
By milton in forum Technical DiscussionsReplies: 3Last Post: 08-02-2004, 01:38 AM -
Tin/Antimony Solder
By Robearbam in forum FundamentalsReplies: 1Last Post: 31-03-2003, 07:18 AM
