    May 2009
    United States
    43
    5
    Pressure transducer calibration
    Looking for a good instrument to calibrate our pressure transducers for suction and discharge pressure on our Frick ammonia compressors. Anyone have an instrument they recommend for this?
    Oct 2009
    merida mexico
    54
    282
    15
    Re: Pressure transducer calibration
    in this maintenance manual calibration procedure for transducers frick, normally reset to zero pressure psig or atmosferic
    Mar 2010
    usa
    120
    I would recommend using a High quality Gauge. But be carefull when setting a Offset. Most Transducers I see with a offset are usualy due to a bad connection at the Input, noise in the Cable or a bad Transducer.
    cl7teckie's Avatar
    cl7teckie Guest
    Well, most other equipment or gauge will "drift" over time. The only low-cost calibration-grade for pressure transducer is using a device that uses dead-weight.
    Sep 2003
    ISRAEL
    72
    4,248
