Results 1 to 9 of 9
Thread: Liquid drier bypass
08-09-2012, 07:47 PM #1
Liquid drier bypass
I was starting up one york chiller about year ago and saw that there is liquid drier bypass without any stopvalves in it.
I'm just wondering why is that build in there?
08-09-2012, 08:15 PM #2
Re: Liquid drier bypass
possibly to absorb moisture and not allow any pressure drop accross the drier
08-09-2012, 08:51 PM #3
Seen a similar set up on a Daikin VRF pipe schematic. It was confirmed to me that some of the refrigerant went through the drier and some bypassed it - still a bit bafflled as to why someone dreamed that idea up.
Cheers,
09-09-2012, 03:09 PM #4
Drier looks undersized for size of liquid line, saves them fitting a removable drier core housing?
alMostly found in the southern part of this green and pleasant land.
20-09-2012, 10:56 PM #5
Mabey they forgot to order the Ball Valves
23-09-2012, 08:33 PM #6
They preempted the drier blocking so that it does not interrupt flow. On the later versions no doubt they changed it a little to fix some unanticipated flaws...............
23-09-2012, 11:17 PM #7
Na...you're all wrong. Thats a handle for lifting out the drier assembly. Can't you see its very heavy.
24-09-2012, 03:40 AM #8
24-09-2012, 06:44 AM #9
Can't be that heavy. It is a Danfoss, and they are so light they make lousy fishing sinkers.....
