Thread: Glycol systems?
    Dec 2011
    36
    131
    8
    Thumbs up Glycol systems?
    Can anybody outline in laymans terms how a glycol system works and why they are used in a system that needs to hit -40?? The system is in a corrosion testing chamber.
    Thanks in advance
    Oct 2007
    manchester
    44
    5,707
    Re: Glycol systems?
    basically a wet system with antifreeze, your glycol circuit will transfer heat from a fan coil unit to the evap shell.
    by using glycol there could be a dry cooler that will give free cooling by rejecting heat from the glycol to the ouside air - free cooling, also the use of an actuator will give close control.
    Dec 2011
    36
    131
    8
    Re: Glycol systems?
    This system uses a cascade refrig system to get to the -40c. I take it this is one refrig system to cool another?
    Dec 2011
    36
    131
    8
    Re: Glycol systems?
    sorry im full of questions, this glycol cascade is all new to me!
    Oct 2007
    manchester
    44
    5,707
    Re: Glycol systems?
    if cascade then the evap of the histage will cool the condenser of the low stage, an intercooler
    http://www.google.co.uk/imgres?hl=en...9,r:5,s:0,i:85
    Dec 2011
    36
    131
    8
    Re: Glycol systems?
    Thanks monkey! thats a great link there!
    RE forum strikes again!
