Thread: NH3 Pipe Sizing
    Jan 2010
    REPUBLIC OF SOUTH AFRICA
    NH3 Pipe Sizing
    Engineers out there.
    Anyone who has free design guidelines on ammonia refrigeration plant pipe sizing either Single Stage or Two Stage flooded systems with NH3 pumps. Will appreciate.
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: NH3 Pipe Sizing
    Hi, ALFONSOTHAWE
    Quote Originally Posted by ALFONSOTHAWE View Post
    you can download Danfoss DirCalc here ...ftp://software.danfoss.com/RA/DirCalc/DirCalc.zip
    then you have CoolPack here http://www.ipu.dk/upload/teknologiud...lpack_1.50.exe
    then you have some on-line pipe calculators like this one ... but you have to register ...http://www.r717.com
    then brochures ...
    http://www.hantech.com/library/pdfs/shut-off/g309.pdf
    http://www.evapco.eu/sites/evapco.eu...131-e_0706.pdf
    There are a lot of suggestions on internet ... just Google ... ammonia ... steel pipe ... sizing ...
    Hope this is of some help to you...
    Best regards, Josip
    Dec 2006
    Iran
    43
    55
    Re: NH3 Pipe Sizing
    dear Friend
    thank you for your information, if you know any software to optimize the cycle and improve COP also mentioned it here.
    Regards.
    Jan 2010
    Thanks Josip. I have one question. Since Danfoss DIRcalc has templates single evaporator system if I want to have multiple evaporator e.g 5 each delivering 30 kW of capacity how do u work out pipe sizing. Do you add all evap capacity and when it gives design size result on piping do you divide that into 5 or there is another method.
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: NH3 Pipe Sizing
    Hi, ALFONSOTHAWE
    of course you must calculate your pipe for the biggest load ... It is simple and not ... for each pipe branch you calculate your full load capacity ... then work out pipe size .... you put together (add) each branch load and you calculate your header for full load, but as evaporators are installed apart each other, then after each evaporator your header must be increased in size for added load ... normally we always start from the last room coming back to engine room .... but there are some other points to consider in pipe sizing .... very important is parallel work of cold rooms, compressors, condensers, then type of cold rooms fresh or frozen goods and here we are coming into deep water ... design of cold store what is not possible to explain here ....
    Hope this is of some help ...
    Best regards, Josip
