Results 1 to 2 of 2
04-09-2012, 07:53 PM #1
Help needed with a LOGIX control panel com setup.
Hi Guys i installed a LOGIX panel on a Howden screw and need it to communicate with a Carel PCo PLC to see the slide position and the Amps to make the logic work behind the controls of the Carel. Do any one know how to set up the com2 port for this and change the board rate to 9600
THE BEST WAY OF LEARNING IS TO DO IT YOURSELF!!!
14-02-2013, 04:58 PM #2
Re: Help needed with a LOGIX control panel com setup.
can you please explain better, and put some images as well
what is LOGIX?
Regards,
Behzad
