Page 3 of 3 FirstFirst 123
Results 101 to 103 of 103
  1. #101
    Oct 2003
    56
    5,519
    28
    Re: COP and Superheat - does is it help?
    Quote Originally Posted by desA View Post
    [at]Peter:
    When you say 'program this all', do you mean as in generate a computer simulation?
    He could 'translate' all these values and plot the real-life cycle on the log p/h graph
  2. #102
    Oct 2003
    56
    5,519
    28
    [at
    If so, than this may help us to establish the movement of variables with our modification of SH. This could possibly also then assist to settle the COP discussion. Not sure mind you, unless the author manages to correctly model compressor efficiency changes, evap & condensor changes, as the cycle changes.
    Would be nice to see in action.
    I had also in mind trying to locate a dynamic simulator for an hvac system. This may, however, also suffer from the same inaccuracies.
    This is where a simple circuit will be so useful. (My heat-pump lab is currently in moth-balls in Laos. Would have run some hard trials & sorted most of this out by now... )
    Peter, or MF, are you perhaps able to run some trials with your rig/system/s? It should take one day, at most, to determine what we need - at least, close enough for us to clarify Chef's dilemma.
    The plan was also measuring current and voltage and then calculating what the actual refrigeration power was (via the Bitzer software) and compared this with actual electrical power.
    We had a polynomial for the Bitzer compressor as well.
    Problem is I have the next 3 months no free minute at all. Even now, I 'm typing this while making a quote.
    We take all the work we can for the moment because I'm expecting the same problem s my colleagues have: lack of jobs.
  3. #103
    Mar 2009
    KZN, South Africa
    58
    2,212
    14
    [at]Peter,
    Thanks so much for your input. Your proposed system sounds incredible. When you have this system up & running, I'd love to collaborate with you when everything is stable. (Would be an opportunity to visit Brugge )
    To work first - not easy times for everyone at the moment.
