Thread: Med Temp Secondary Cooling Leaks
02-09-2012, 08:53 PM #1
Hi all,
Just wondering how fun it is finding Glycol leaks on a Pumped Secondary System in a Supermarket.
On a DX system, a hand held Leak Detector will get you into the leaking case,or at least the line up with a leak.
Pulling deck pans or kick plates checking floor drains looking for Glycol isnt fun.
Any thoughts?
02-09-2012, 09:02 PM #2
Re: Med Temp Secondary Cooling Leaks
just keep topping the system up and the leak should show itself
saves stripping each cabinet,checking pipe runs,drain outlets
02-09-2012, 09:26 PM #3
