Results 1 to 40 of 40
Thread: Car Air Conditioning Problem
04-09-2012, 06:45 PM #1
Re: Car Air Conditioning Problem
check the air gap between the clutch plate if the gap is large the comp run when cool but when the comp gets hot the gap gets bigger and the electro magnetic coil will not p ull the plate in too drive the comp
04-09-2012, 09:44 PM #2
If you have a feed to the coil then as Ian says there could be a fualt with the air gap - I think Volvo's amongst others suffered with that.
To test the coil measure it for resistance. I think the one on our Astra was around 150 ohms. You'd need to check it when it is getting a feed but not cutiing in.
Cheers,
