    Aug 2012
    India
    9
    Seawater cooled Condensor
    Hi all,
    I'm new to this forum and this is my first post. I hope I get some good response here.
    For a seawater cooled condenser, will there be a cooling tower? Or will it be an open loop of seawater that cools the refrigerant?
    Dec 2008
    Portugal
    48
    1,020
    Re: Seawater cooled Condensor
    It will be an open loop of seawater.
    If you would use a cooling tower in a closed loop with the condenser then the condenser could work with fresh water.
    Mar 2012
    New Zealand
    2
    I've been using Titanium heatexchangers tube in tube since 1989, that is a plastic barrel with Titanium tubes. Put in a waterflow switch to turn off the thermostat power supply if no water. Put in HP/LP gauges to ensure the correct waterflow. Do not use a Titanium plate heatexchanger unless you can filter water down to 250 micron before the Heatexchanger/condensor.
    Sep 2012
    India
    77
    13
    Is it for land based application or for marine vessel?
    Aug 2012
    India
    9
    Its land based. I'll share more details later..
Tags for this Thread
