Thread: cooling tower without fillings
26-12-2005, 02:33 AM #1
Hi sirs
One customer wants me to review the performance the small cooling tower without fillings. It's supposed to be used to couple with a 9.8kw chiller which use this kind cooling tower. I think it's must be lower efficient than normal cooling tower.But how much the difference between the cooling tower with and without fillings? Who have this experience or any ideas? welcome to comment -
best regards
LC
26-12-2005, 08:23 AM #2
Re: cooling tower without fillings
Good morning Lichuan,
If you say without fillings, do you mean without water in the reservoir?
If so, it's just the water that cools down enormous the discharge gasses from the compressor.
You can't use anymore the dewpoint temeprature to lower condensing temperature.
Read once though this section, if any problems reaching this section, let me know.
http://www.baltimoreaircoil.com/engl...ter/index.htmlIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
26-12-2005, 04:11 PM #3
The 'filling' is sometimes used to prevent water carry-over, from the pumped cooling water, being blown out of the tower.
27-12-2005, 12:55 AM #4
thanks for your input.
the fillings or fill is the PVC (made like honeycomb) in the cooling tower which increase the contact area between water and air and enhance the heat rejection.
i'm studying some material for it.
regards
LC-I hear...I forget;I see...I remember;I do...I understand
cooling tower & humidity
By afeef in forum FundamentalsReplies: 4Last Post: 11-05-2006, 02:41 PM -
Cooling Tower Design
By jteixiera in forum Tools and CalculatorsReplies: 10Last Post: 31-01-2006, 12:23 AM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Cooling tower water pumps
By reggie in forum FundamentalsReplies: 1Last Post: 13-08-2003, 08:18 PM
