Results 1 to 10 of 10
22-08-2012, 04:53 PM #1
Serial Communications with Denco Precision Units
Very first post and decided to register finally after web searching has lead me here so many times. I have a bunch of different Precision Air Handlers from Denco with three different controllers.
C3-05(I know its actually CAREL controller on this one)
Millenium
Beta 2
I have the manuals on all of them, and need to get the serial cards that communicate with them. I know exactly which one I need for the C3-05, but for the other two I have no idea what it looks like. Anybody have any idea whom to contact to find out where/if these can be purchased/quoted.
Thanks,
elHR
22-08-2012, 06:20 PM #2
Re: Serial Communications with Denco Precision Units
Rob Woodworth
GEA Denco Technical Support
rob.woodworth@geagroup.com
22-08-2012, 06:53 PM #3
Thanks for the help
24-08-2012, 08:09 PM #4
Trying to figure out what connects to this. This is the board for a Beta 2. Any idea how these controllers can be linked together. Apparently they can be linked somehow. The PL3 socket has the option of RS422, RS232, and a few others. Or just any idea of what kind of general connection hooks to it.
24-08-2012, 08:39 PM #5
is that the 1 thats got a trend display if so either a rj45 plug or tx+- rx+- a 4 pin plug
24-08-2012, 09:13 PM #6
This is the display for the controller
24-08-2012, 10:59 PM #7
yep thats it, the 1 with 3 levels of passwords and a factory password up down up down up down!
Last edited by install monkey; 24-08-2012 at 11:00 PM. Reason: factory password is up,up,up- the other levels were up/down/ repetitive
27-08-2012, 02:32 PM #8
Ok, so nothing connects to that PL3 serial port I pointed out in the first picture or is the rx/tx on the other side of that board?
27-08-2012, 03:37 PM #9
ive dug out the service manual that is well worn, and it states for external bms connection use a rs232 serial output port no pics of board for connections or part numbers
07-10-2012, 02:27 PM #10
You wont connect different controllers together to talk/control together. they need to be the same controller with the same software version
