Hello everybody here,
My pleasure to be here with that professorial refrigeration community, and here is what i am asking about:
I need to calculate the cooling capacity and electric power consumption of a water tank which is:
5000 liter volume, containing water which required to reduce from 55 Celsius degrees to 25 degrees, drains 1000l/day.
Tried to use HAP software, but couldn't with my project, so do you know any other softwares which can help with that project?.
Thinking to calculate manually, using formula of Q=M*C*delta T and add the Q of the solar heat gain, but not sure about how to apply these formulas on my project.
will appreciate your reply,
Thanks.
