Thread: Old coca cola cooler
15-08-2012, 05:54 PM #1
Derby DK9620p AAlstrup coca cola bottle fridge,idiot has pulled the front panel off breaking the thermostat phial and pulled off all the wiring to stat,door switch lights etc
It was switched on plugged in and he couldn't work out why it wouldn't work,staff working there,folks should have to sit a check to see they are competent employers not unnecessarily putting staff at risk.
In a tight spot and no room to work,cant trace wiring so hoped someone might have a wiring diagram.
Worrying thing is they see nothing wrong in what they have done!
“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
15-08-2012, 06:16 PM #2
Re: Old coca cola cooler
Not a clue on the wiring.
We have a customer whos solution to his staff getting shocks off a prep counter was to supply them with wellingtons.... some people shouldn't be allowedMostly found in Oxfordshire, UK :)
15-08-2012, 09:14 PM #3
Put in an off cycle digital controller, leave the evaporator fan on permanent, stick in a rocker switch for the light.
alMostly found in the southern part of this green and pleasant land.
16-08-2012, 12:35 PM #4
He's decided to scrap it,so just the call charge will do nicely thanks!
16-08-2012, 10:18 PM #5
the weigh in would be nicer!- laugh if it was a rental!! haha
17-08-2012, 06:51 AM #6
003ikw.jpgThere was about 2 inches clearance above what was left of the top and the ceiling!
First thing I did was check supply which was plugged in and switched on !“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
