Thread: 410a manifold
10-08-2012, 07:44 AM #1
410a manifold
If one is merely using a manifold through which to evacuate a system or to weigh in additional refrigerant does it matter if one were to use 410a manifolds with 134a refrigerant?
10-08-2012, 08:24 AM #2
Re: 410a manifold
Why not ......
10-08-2012, 10:06 AM #3
Re: 410a manifold
It is possible. But not the other way round or u will suffer the quinciquonces !!!!!!!!!!!!!!!!!!!!!!
10-08-2012, 10:22 AM #4
10-08-2012, 12:37 PM #5
Re: 410a manifold
lol. Yeah re the other way around. Higher pressure isn't it?
As it is I'm only licenced to do single head splits so I guess a set of 410's is all I'll need. Saves a bit of cash I suppose.
27-08-2012, 02:52 PM #6
Re: 410a manifold
I don't use 410 - does 410 plant not come with different sized gauge line fittings, to stop this cross-over? I thought it did
27-08-2012, 02:58 PM #7
Re: 410a manifold
5/16 connections on systems- 1/4 at the manifold- also qwik couplers for 5/16 and 1/4 have the same internal diameter so you can use 410 manifolds on anyhing except ammonia systems
