    ireland
    1,450
    carrier chiller fault codes
    Hi all
    Would anyone have the fault codes for a 30RA007 chiller, unit has no display so is it possible to fault find without a laptop?
    Al
    Feb 2005
    Aberdeen
    48
    168
    Re: carrier chiller fault codes
    Hi Al. Is this chiller of the flowtronic series and how old is it? I have some info on carrier faults but may not respond to this particular model.
    regards
    Jase
    rbartlett's Avatar
    rbartlett Guest
    these are fairly new aqua snap type thingy ma bobs
    go here
    http://www.xpedio.carrier.com/idc/gr...ments/techlit/
    and 'find' 30ra
    there are several files and one may have the codes
    cheers
    richard
    edwuntalan's Avatar
    edwuntalan Guest
    Hello everybody! and Welcome to refrigeration Engineers. Does any body have an error codes for fujitsu vrf?
    Nov 2007
    IRELAND
    11
    If you have a 30ra without a display give up & buy a display you can take it with you when you have finished the job for future use as it will just plug out of the top of the board
    Naseer's Avatar
    Naseer Guest
    Hi All
    we dealing all kind of chiller used (good working condition compressor).
    4,698
    Hi Al.
    I did a search and discovered this hand held unit.
    (see attached pdf.)
    I am not sure whether it is relevant but if the age is correct.
    It would appear that this unit is now obsolete.
    Cheers Grizzly
    ireland
    1,450
    Grizz
    thanks for tracking that, chiller was switched off and unit has been cooled by mains water since that post, might be replacing the unit this year?
    al
  1. carrier fault codes
    By mr saw in forum Air Conditioning
    Last Post: 30-06-2010, 03:31 PM
  2. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  3. carrier fault codes
    By coolflow in forum Technical Discussions
    Last Post: 04-10-2009, 02:29 PM
  4. Chiller fault
    By iceman007 in forum Trouble Shooting
    Last Post: 27-06-2006, 06:15 AM
  5. Chiller Fault
    By iceman007 in forum Air Conditioning
    Last Post: 13-05-2006, 07:23 PM
