Thread: HP Rating
08-08-2012, 08:27 PM #1
HP Rating
Hello.
My refrigerator compressor's datasheet says that the cooling capacity at -23.3 degrees C is 240 watts. Does this mean that it is a 1/3 HP compressor? Or is it still in the 1/4 HP range?
Also, someone in the refrigeration store said that 1/4 HP compressors use the same size capillary tube as 1/3 HP compressors, is this true?
Thank you for your time.
Visit http://www.kompulsa.com/ for technology news, reviews, and more. Twitter: Kompulsa.
08-08-2012, 10:50 PM #2
Re: HP Rating
What is the compressor model, we can't see the data sheet from here, sorry.
10-08-2012, 03:08 PM #3
Re: HP Rating
Here is the compressor datasheet: http://www.megafileupload.com/en/fil...80HAW-pdf.html
10-08-2012, 06:12 PM #4
Re: HP Rating
If you read your own data sheet you will be able to see that answer that you seek, it's all there in black and white.
12-08-2012, 08:44 PM #5
Re: HP Rating
12-08-2012, 11:04 PM #6
Re: HP Rating
The size of the capillary depends on the design of the system, not the size of the compressor.
17-08-2012, 04:30 AM #7
Re: HP Rating
1/4 HP range
