    learningnh3's Avatar
    learningnh3 Guest
    Insulating hot gas lines
    Hi Everyone,
    I was hoping you guys can help:
    Is it common to insulate hot gas lines in industrial NH3 systems? A little bit of back ground, +25F/85F
    NH3
    Liquid Recirc
    THANKS!
    Sep 2008
    Canada
    811
    Re: Insulating hot gas lines
    It depends. Defrost hot gas line should be insulated. Hot gas line between compressors and condensers shouldn't.
    May 2012
    59
    1,528
    36
    It does depend on what the hot gas line is used for.
    Where is the hot gas going and will you still need it to be
    hot when it gets there?
    If you are using the hot has for defrost purposses or for
    heat recovery then it would be recomended to insulate the
    pipe, if the pipe is the discarge from the compressor to the
    condenser then usualy no, do not lag the pipes.
    Rob
    Jun 2002
    628
    23
    Insulating the discharge line is sometimes specified where there is a risk of burns.
    May 2012
    59
    1,528
    36
    Quote Originally Posted by Mark View Post
    Thats correct and also if the condensers are remote to the
    compressor the discharge is insulated to prevent the
    discharge gas de-superheating before it gets to the condenser.
    Rob
    Sep 2008
    Canada
    811
    i don't think that desuperheating is bad. Actually, it helps to reduce heat rejection that required by the condenser. However, hot gas condensation in the discharge line is bad and insulation can help.
    Mar 2010
    usa
    120
    Defrost lines with the chance of condensing refrigerant should be to prevent Shock when a defrost started.
