Results 1 to 1 of 1
12-07-2012, 10:14 AM #1
Daikin multi high pressure at low side
I have a Daikin multi 4mxs68f and i have pressure 200psi at low side for r410a.I should have from 100-150psi.The air temperature at the exit of the machine is 17c as a result i dont have good cooling at the rooms.
I tried the test with the control but everything seems to work ok.
Liquid side pressure 320psi vapor side 200psi. My ampers is according the manufacture.
Any ideas to help me?
Thanks in advance and sorry for my english
