Results 1 to 2 of 2
    Oct 2008
    newbury
    1,444
    37
    American voltage equipment in the UK
    Chaps
    I am after prices for some evaps and condensers for an american unit. It is to be fitted out in the Uk but spend it's life in the good ole US of A
    Therefore I need everything you need for a freezer room evap, cond sol, panel but using US> 1, 2 & 3 phase 60Hz
    I was thinking sea container suppliers are a likely source??
    Somerset
    69
    4,698
    Re: American voltage equipment in the UK
    Hi RB.
    A marine source is a good shout. As they are where i have mostly come across 60hz equipment.
    A chat with some of the suppliers may give you options as many modern fans are dual voltage.
    The hertz rating may well be the sticking point?
    Sorry I cannot be more constructive only yours is the opposite to what I have experianced.
    Good luck Grizzly
