Results 1 to 11 of 11
Thread: house duct design infromation
15-12-2005, 09:58 AM #1
hello all, at this time i only supply and fit splitsystems, can any one point me in the right direction where to find some usefull information on duct design for a standard house my be found.
15-12-2005, 10:06 AM #2
Re: house duct design infromation
G'day Peter
Somewhere on this site Marc Obrien posted a link on a ductulator he had designed.
If you can find it check it out.
15-12-2005, 03:26 PM #3
You can also look through the Trane book store for educational material you can purchase over the net.
I have some of these and they are well worth the small amount money you will pay for them.
http://www.trane.com/Commercial/Location.aspx?Item=3
15-12-2005, 04:45 PM #4
http://www.ventaxia.co.uk/sharing/
give this link a try
cheers
eggs
15-12-2005, 04:54 PM #5
15-12-2005, 06:16 PM #6
You're nothing with a calculator if you don't know how to input everything and make a judgement of the results if they're somewhat in the expected region.
15-12-2005, 07:53 PM #7
Originally Posted by Peter_1
Using calculators/software programs is the absolute worse thing anyone can do, if they do not know what the results mean.
Programs can be dangerous, since you input data, and get data out. You need to know what the output data means, AND, if the output data is correct (or close enough).
Programs & calculators should only be used by someone who understands the process, whether it is pipe sizing, duct sizing, or selecting compressors.
15-12-2005, 10:21 PM #8
Exactly right.... I completely agree.
RegardsLast edited by botrous; 15-12-2005 at 10:25 PM.
15-12-2005, 10:35 PM #9
Excuse me chaps, i was under the impression the fella was asking for information on designing simple duct systems? NOT asking for a magical calculator.
cheers
eggs
16-12-2005, 01:56 AM #10
try these for information...
http://www.warmair.com/html/duct_dynamics.htm
http://www.energy.ca.gov/efficiency/...PROCEDURES.PDF
http://www.toolbase.org/docs/MainNav...stemdesign.pdf
http://www.airah.org.au/downloads/2002-10-01.pdf
http://www.smacna.org/bookstore/inde...token=76712760
I highly recommend obtaining a design manual from either Trane or Carrier for this. If you have not done this before, it would be prudent to have a qualified person review the selections and layout.
An ounce of prevention, is by far cheaper than saving a few dollars, pounds, euros or quid.
Hi botrous,
..we already discussed that and you know that I do agree with you completlyyyyyy
16-12-2005, 11:48 PM #11
Using a program can create more problems than those solved.Engineering, sciences, math, physics and my brain will generate "not responding " soon
capillary tube design
By Chris Zahrt in forum FundamentalsReplies: 5Last Post: 04-06-2009, 09:16 PM -
Duct Size Help!
By Robearbam in forum FundamentalsReplies: 9Last Post: 04-04-2003, 01:44 AM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
