06-07-2012, 05:06 PM #1
Whirlpool fridge ARC0820 which does not cool enough
I have a small Whirlpool fridge ARC0820 which does not cool enough (trays are cold but food just little bit). I have bought and replaced compressor relay but temperature seems to be same :cry:
I can hear compressor running.
Could you please help ?
06-07-2012, 05:34 PM #2
Re: Whirlpool fridge ARC0820 which does not cool enough
need to check thermostat and maybe refrigerant
08-07-2012, 10:45 AM #3
Do you know where is thermostat located?
08-07-2012, 04:05 PM #4
You need to establish if the compressor is running constantly,if it is and not achieving correct temperature then its not the thermostat,would be folly to change unless you are sure.
Also if the compressor is running constantly and extremely hot to the touch then its more likely a system fault,either lack of refigerant or poor compressor performance.
If the latter then you will need engineer or repacement fridge.“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
