    Jul 2012
    Unhappy Hotpoint FF200LP Fridge fault.
    I have a Hotpoint Ff200LP fridge freezer with a common fault of the freezer element freezing up and causing the fridge to not work.
    It works fine if I manually defrost it, and I beleive the defrost circuit is failing somehow.
    I have checked continuity of the heater element and I beleive it to be withign spec for 220w.
    I have checked the Thermal cutout and this too seems to be OK. (continuity between 2 yellow, and 2 blues)
    I suspect it may be a control board failure or somethign that I havent yet tried.
    Is there anywhere I can get a diagnostics manual for this model?
    Any help appreciated.
    Jul 2006
    norfolk
    737
    Re: Hotpoint FF200LP Fridge fault.
    send us email at i send u some tech.... airkool@hotmail.co.uk
    Jul 2012
    Thanks you very much. . . . done
    Jul 2012
    I have got somewhere with this now!
    I ran some built in diagnostics and have come up with fault code F25, Freezer evaporator NTC sensor
    open / short circuit.
    Is this the Evap thermister that I keep reading about?
    If so does anyone know where I can get one at reasonable cost?
    I had a lot of trouble confirming which was the correct item on the hotpoint spares website. I called them and they were as much use as a chocolate fireguard.
    I'm happy to buy the part but I need to confirm that I have identified the correct one.
    I may have found the correct part!
    http://www.pandorasoem.com/Genuine-G...New_p_943.html
    or
    http://www.ebay.co.uk/itm/1209634808...819%26_rdc%3D1
    pandoras's Avatar
    pandoras Guest
    First of all, check the compressor of your fridge. For More information please visit www(dot)pandorasoem(dot)com.
    Jul 2006
    norfolk
    737
    whats the compressor got to do with this fault?
    check out my website www.airkooldomestics.co.uk
Tags for this Thread
