Thread: Hotpoint FF200LP Fridge fault.
06-07-2012, 12:29 AM #1
I have a Hotpoint Ff200LP fridge freezer with a common fault of the freezer element freezing up and causing the fridge to not work.
It works fine if I manually defrost it, and I beleive the defrost circuit is failing somehow.
I have checked continuity of the heater element and I beleive it to be withign spec for 220w.
I have checked the Thermal cutout and this too seems to be OK. (continuity between 2 yellow, and 2 blues)
I suspect it may be a control board failure or somethign that I havent yet tried.
Is there anywhere I can get a diagnostics manual for this model?
Any help appreciated.
06-07-2012, 09:05 AM #2
Re: Hotpoint FF200LP Fridge fault.
send us email at i send u some tech.... airkool@hotmail.co.uk
06-07-2012, 02:23 PM #3
Thanks you very much. . . . done
26-08-2012, 10:12 PM #4
I have got somewhere with this now!
I ran some built in diagnostics and have come up with fault code F25, Freezer evaporator NTC sensor
open / short circuit.
Is this the Evap thermister that I keep reading about?
If so does anyone know where I can get one at reasonable cost?
I had a lot of trouble confirming which was the correct item on the hotpoint spares website. I called them and they were as much use as a chocolate fireguard.
I'm happy to buy the part but I need to confirm that I have identified the correct one.
I may have found the correct part!
http://www.pandorasoem.com/Genuine-G...New_p_943.html
or
http://www.ebay.co.uk/itm/1209634808...819%26_rdc%3D1
06-11-2012, 06:27 AM #5
First of all, check the compressor of your fridge. For More information please visit www(dot)pandorasoem(dot)com.
06-11-2012, 07:16 AM #6
whats the compressor got to do with this fault?
check out my website www.airkooldomestics.co.uk
