Results 1 to 11 of 11
    Jul 2012
    Spain
    67
    4
    What compressor type/brand can I use to replace a Unite Hermitique AEZ2415Z
    I have a small Slush Machine company in Spain and have continuous problems with my machines that have a UH AEZ2415Z compressor. I also have machines of a different brand and type that use an ASPERA compressor and with them I never in 5 years have had a problem.
    I do not have the knowledge to determine what compressor of ASPERA would qualify to replace the AEZ2415Z . Can anyone help me and give a suggestion ? It can be any brand but Unite Hermetique .
    Regards,
    Paul
    Oct 2008
    newbury
    1,444
    37
    Re: What compressor type/brand can I use to replace a Unite Hermitique AEZ2415Z
    Why don't you google it?
    Jul 2012
    Spain
    67
    4
    I forgot to mention that I tried to Google it for days before I decided to post on this forum of experts .
    Oct 2008
    newbury
    1,444
    37
    http://www.hawco.co.uk/userfiles/Med...20pg%206-7.pdf
    look at the compressor comparison page
    ireland
    1,450
    41
    This is the technical info on the AEZ compressor, show it to your supplier and ask them to match an Aspera to it, if 2 models match go for the bigger capacity compressor.
    al
    3,856
    I find L'Unite stuff pretty bomb proof, maybe the problem is in the design of the slush machines?
    ACC
    Electrolux
    Unidad
    Danfoss
    Aspera
    Embraco
    LG
    Sep 2003
    ISRAEL
    72
    4,248
    Aspera was bought by Embraco a while ago. Very good and reliable compressors.
    The also manufacture small condensing units.
    They will be cheaper than L'unit.
    Jul 2012
    Spain
    67
    4
    Thanks for the advice.
    I now have bought a danfoss FR8 5CL compressor which has about the same capacity as the UH original compressor. I filled the new compressor with the same amount of R404 Gas ( 242Gr) and ran it against a UH original compressor. It shows the Danfoss performs worse, the UH started forming ICE on the evaporator after 14,5 min. and the Danfoss after 21 min.
    Should I just give up and stay with the UH compressor which is short lived , or can it be that the Danfoss needs a different amount of R404 charge to be most efficient ? I am not an expert on the field as you may have discovered, just asking for advice as nobody else has been able to sort this thing out for me so far.
    Regards,
    Paul
    Feb 2007
    2,473
    45
    OFN whilst changing?
    New drier?
    Vacuum to 500 microns? Standing?
    Subcooling?
    Superheat?
    So many questions...
    ireland
    1,450
    41
    You need to match the compressor to the needed capacity, then charge would be fairly critical on such a small system. Is there no fridge men that can help you there? Have you any calculations that you used to choose the compressors in the first place?
    al
    Jul 2012
    Spain
    67
    4
    Replacement compressor was found through http://www.hawco.co.uk/userfiles/Med...20pg%206-7.pdf
    which is the compressor comparison page I was suggested to use.
