    Apr 2012
    Iraq
    35
    623
    how to properly charging system
    hi
    after vacuuming system
    if i want to charge it
    what is the best way
    as example
    if i have 2 ton window type ac and r22
    some people say
    i must charge it with liquid in the beginning then after turning it i must charge it with vapor only
    other say i must charge it with vapor when unit is off
    then after turning on it i can charge with liquid and vapour
    so what is the properly way to charge ac
    others say
    Power consists not in being able to strike another but in being able to control oneself when anger arises
    Oct 2007
    manchester
    5,639
    45
    Re: how to properly charging system
    Apr 2012
    Iraq
    35
    623
    sorry the link you put is dazed me
    ok if you dont mind
    i am doing this charging by this way
    when unit is off i charge unit with liquid only by weight through suction line
    then after turning on unit its suction pressure is 60 or 70 psi
    and i found no need to add r22 because suction line is being very cold which mean unit has required quantity of *****
    what is your opinion
    Oct 2007
    manchester
    5,639
    45
    if you can fit gauges to both sides of the system let liquid in the high side until you cannot get any more in-observe the weight charged- system will stop taking in liq,shut gauges and start system- open low side and charge vapour slowly to finalise the charge- if needed you can add liquid in the suction line to get all the charge in but do it slowly .
    Quote Originally Posted by kefah View Post
    ok if you dont mind
