Results 1 to 8 of 8
    Jul 2012
    44
    3
    Fuijitsu Mini Split Condenser Question
    Hello, I have a question regarding Guijitsu Mini split system.
    I installed everything according instructions except Air Pumping and as I was reading It's required. All valves have not been opened yet. However, I tested indoor unit (turned it on) and it's working fine as fan As there is no cooling going into pipes. I will try to pump air out and check all pipe connections. But I noticed that outside unit doesnt start/work or anything. So the question is ..
    Is it normal for outside unit to be silent/inactive until valves are opened?
    I am hoping after purging air it will work
    Oct 2007
    manchester
    5,639
    45
    Re: Fuijitsu Mini Split Condenser Question
    as the manual should say - connect wiring and pipes - pressure test ,vac then open service valves- add any additional refrigerant then run system- 3 min delay on outdoor unit running from a demand for cool/heat if not at setpoint, do not run with valves closed
    3,856
    Quote Originally Posted by stasbeletsky View Post
    Its not normal to run the system with the service valves shut...
    Hope is a wonderful thing, sometimes its all we have.
    Best fully follow the instructions, if you are not a tech then its best to get someone qualified to commision the system for you or it will be nothing but trouble.
    Oct 2008
    newbury
    1,444
    37
    Poor unit... :-(
    Jul 2012
    44
    3
    Is it often that outside (or inside) unit malfunctioned? Is just bad luck? Covered by warranty?
    Basically I purged air, tighten all connection (it was a little leak) and opened valves. So system has been charged. But outside unit is still silent.
    Calling some contractors to see it in couple days.
    Nov 2008
    birmingham
    155
    good luck with that, warranty should be void as not installed by a qualified engineer.
    Jul 2012
    44
    3
    Hey, thanks all for replies Basically problem was with power line ... I put 110 ... and unit (of course) didnt run except indoor fan, so i set another line (double breaker/fuse) for 220 and it works just fine... my stupid mistake... thanks again
    Oct 2001
    Nottingham UK
    5,668
    [QUOTE=stasbeletsky;261649] it works just fine... [\quote]
    For now.....but don't expect longivity
Tags for this Thread
