    Dec 2006
    Iran
    43
    55
    Question How to solve STT fail Error on MYCOM CPIII , VLD200
    Dear Friends
    Hi, We have a Mycom 200vld compressor and it was work well but , it just stop some times and show STT fail on CPII monitor.
    i check the manual and it said that :
    compressor running confirmation,a contact of the motor starter on digital input2 , is not detected by the CP-III/E when compressor start signal was given.
    Does anybody know how to get ride of this alarm and solve it?
    Somerset
    69
    4,697
    Re: How to solve STT fail Error on MYCOM CPIII , VLD200
    Hi Jahangir.
    A good place to start would be to check your Compressor Motor Start Feedback.
    Which has a relay (MSRB) which is normally open circuit through terminals 12a and 12b on your Digital input / output board. this circuit makes on start-up.
    It could be as simple as the relay has failed?
    Worth a check anyway.
    wiring diag. to follow.
    http://www.mediafire.com/?ab67syeepmc7cah
    Wiring diagram. may help?
    Dec 2006
    Iran
    43
    55
    Hi Grizzly.
    you mean than , when compressor is running the 12a and terminal COM should be close? if then might be another problem or something else?
    I check the file . so thanks anyway
    Regards.
Tags for this Thread
