Results 1 to 2 of 2
    Aug 2011
    vietnam
    VSD for chiller at high lift conditions
    Hello all,
    For centrifugal chiller, many comments about reduce lift when unloading chiller - compressor speed chiller. But for VSD screw chiller (carrier, york) is this principle still working ?
    Auckland
    68
    3,362
    32
    Re: VSD for chiller at high lift conditions
    generally speaking centrifugal compressors require optimum impellor tip speed to be driving force for compression, so they have variable inlet vanes to alter flow rates.
    Variable impellor speeds would have compounding /negative effect of vapour flow rate through compressor. Effectively you will get slippage from high to low pressure zones, sounds horendous and prematurely damages mechanical components like thrust assemblies.
