    uk
    73
    Condensate pump for underceiling unit
    Got a few 14kw single blow underceiling units to fit in a new nightclub. Its a friggin nightmare to find a pipe route out of the place. I'm going to have to use condensate pumps, with no space external to the units to put them.
    I cant remember the last time I fitted an underceiling and never been so stuck for space around them. Is there a RELIABLE condensate pump out there that will fit inside the indoor unit???
    Thanks in advance.
    Oct 2008
    newbury
    1,444
    37
    Re: Condensate pump for underceiling unit
    mini aqua for me
    Oct 2007
    manchester
    5,639
    45
    mitsi- power inverter do a built in lift pump- same as the cassettes- good for 700mm lift- mini aqua's are good but the float assembly and pump are 1 peice so you have to change the lot- sauermann delta's have 2yr garantee and no inlet gauze and will pump up 8mtr!-comfirmed- best bet is a 1ltr hi lift tank pump and fix it on the back of the unit-seen aspen perisaltics used as the underceilings have a big drip tray- blue diamond mini blues are ok they have an overrun of 20minutes and in a night club you wont hear the constant gurgling when no water!
