21-06-2012, 09:56 PM #1
Carrier Vector 1800: A41, A100... engine stalled
hi guys
had a Vector today with A41 and A100 (engine stalled), think one has sth to do with the other..
new charger, was ok for a few days.. now it changes language (C1/C2 switch?!?) and again engine stalled after few seconds (alarms 41, 100, comp. suction and discharge, etc..)?!? any idea what to check before ordering new Gene?
thks
parisienne
22-06-2012, 10:39 AM #2
Re: Carrier Vector 1800: A41, A100... engine stalled
Hi, you need to determine why it's cutting out, is the ogf module working properly, is there excessive load on engine when contactors engaging ie condenser fan, compressor, evap fan, heater bars. I would also check the micro and plugs for water damage or corrosion if it's throwing up lots of faults
22-06-2012, 06:17 PM #3
hi 123smc
found it this morning, there was water damage on a connector. 7 alarms gone, last one stalls engine (suct pressure). might be a problem with micro (MP15&29) or the csp itself?!? csmv works fine..
