    Jun 2012
    jamaica
    2
    converting a/c unit to accept solar power
    Hi any technical issues to stop you from converting a traditional a/c split unit to accept power from solar panels .. What would it require to do it ?????????
    Oct 2007
    manchester
    5,639
    45
    Re: converting a/c unit to accept solar power
    http://www.kompulsa.com/
    try here for info-good luck
    Apr 2007
    36
    371
    23
    Quote Originally Posted by install monkey View Post
    Agreed!
    Jun 2012
    jamaica
    2
    no useful info on that site need some from other sources.. who has info on solar inverters this is what is required to convert a conventional water heater/ a/c etc ??
    Apr 2007
    36
    371
    23
    Im not sure what your asking...
    You want to use solar PV panels to power your AC unit...instead of coming off the national power grid?
    J
    Dec 2010
    Toronto, Canada
    1,454
    Forget it........
    Pump your power into the grid, net meter it, and draw it out for the AC. Anything else is waaaayyyyy to complicated.
    Kompulsa, if he has not blown himself up yet, might have tried it.
