Results 1 to 1 of 1
Thread: This is what i want to do.
02-12-2005, 08:14 AM #1
Well i have recieved a fridge on R134a ,Fan forced evap
induced fan condenser. It is a commercial shop fridge.
It is a project at home, i want to fit schraders and service valves to the system to read pressures at different points at different loads.(yes i am in the trade)
Any thoughts where you would put them ?
I'm thinking on the same lines as you have 4 or 5
different systems in the 1 !
Tx, cap tube, float type controls.
the later being hard as it has no bore but maybe, used in conjunction with a reciever it might work.
A control to isolate different parts of the system (eg)(compressor,fans,flow controls,lights,relays)
Also maybe a series of sight glasses in the evap and condenser to show the flashing off of the refrigerant.
ANY IDEAS ?
2nd year apprentice.
Yes you may have seen this before.
The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
