Results 201 to 226 of 226
13-04-2013, 09:22 AM #201
Re: k20 Ignis Blizzard icemaker issue with not starting
Yes it's working fine, the heat is required to drop the ice as its such a big slab of it.
13-04-2013, 05:57 PM #202
Allright.
I never took notice of the pause between the ice harvest mode and the ice making mode.
It stalls(stops working for a while and then the compressor works).
I think this is because the temperature on the evaporator rises up to 40C and then it have to come down to ambient temperature in order for the compressor to even start kicking in.
Not sure how it is made exactly there.
So the ice maker was sold because it was slowing production. it is 2x as slow as advertized, making half the amount of ice cubes in 24 hrs.
13-04-2013, 07:01 PM #203
http://www.thetickletrunk.com/17-air...eel-containers
Google produced me these containers to store ice inside.
Overrated?
Or looks good?
16-04-2013, 07:07 AM #204
how does one keep these ice blocks from sticking in the freezer?
They are wet ice blocks.
Unless you freeze the whole slab!
i guess these commercial ice machines are made to have the ice to be there to be served.
have them run for half a day and have ice in the machine for your clients.
I am looking at ice picks to buy at the moment:
http://www.****tailkingdom.com/produ...x_0000_sma.htm
24-04-2013, 12:28 AM #205
http://theprayinglife.files.wordpres...t-ice-pick.jpg
I bought an ice pick in the supermarket for a few dollars like this one.
I ussually take out the ice bags. Which are in the freezer like one big lump of ice and break them up and put the loose ice back in the bag. This make it easier to make the ice loose when you go take more ice the next time.
It works for now.Last edited by xbox40489; 24-04-2013 at 01:25 AM.
28-04-2013, 07:57 PM #206
I found this whilst tidying my van earlier. Better late than never.
Andy
07-05-2013, 11:58 PM #207
Hehehe
yeah Andy, thanks for that explanation.
The calibration screw i figured it out, while testing the machine a couple of weeks ago. Trial and error.
But my ice making cycles are still taking too way long, about 55 minutes long each. Even the 2nd or 3rd cycles.
I can live with that though, seeing I do not operate it for a restaurant/hotel that needs constant ice cubes production in a short time.
I just have the machine make ice and come back in a few hours and bag the ice and put it in the freezer for later use.
It is only a few of us using the ice cubes. Sometimes I make icy drinks it takes a lot of ice(frapuccino's, pinja colada etc).
The tray ice cubes in your fridge just have a scent and aftertaste to them.
Ice machine ice cubes are better and melts less quicker.
I am looking into making ****tails, now the ice machines is back working.
08-05-2013, 07:46 PM #208
now its working you could get 1 of theses and be a proper party conisseur!
http://www.smythstoys.com/kitchens-h...122280itm.aspx
09-05-2013, 07:55 PM #209
Now that's a bit of kit to install :-)
11-05-2013, 04:20 AM #210
Nah now it is turn to check out an Air Conditioning!
This project:
http://www.refrigeration-engineer.co...ht=#post263587
On topic:
I met a old and rusty scottsman at a Restaurant near a beach lately where I go often for my job. I haven't checked out the ice quality of that one. But it is a big machine.
Also I when you know more about ice machine you will think if the water is filtered. And if it is what about the cleanliness inside this machine. I need to ask them there to have a sample.
Also I should order that TDS meter:
Water quality:
http://www.buydirectwaterfilters.com.../t_d_s__meter/
A TDS Meter indicates the Total Dissolved Solids (TDS) of a solution, i.e. the concentration of dissolved solids in it. Since dissolved ionized solids such as salts and minerals increase the conductivity of a solution, a TDS meter measures the conductivity of the solution and estimates the TDS from that.
Source: http://en.wikipedia.org/wiki/TDS_meter
To be more critical on my water quality and others.
Also when I drove by this week by a supermarket. I saw the ice truck unloading the old bags of ice cubes out of the freezer where they keep these ice bags. And replenish it with fresh new bags of ice cubes. In the Caribbean(read more St Maarten) here it is common to go to the supermarket and buy your bag of ice.
There must be a lot of waste. When it comes to these ice cubes bags. Sold at I guess 2-3 dollars a bag to the consumer.
A few years ago I already bought me a blender which makes icey drinks. Think of frappuccino or pinja colada etc.
I need to get me the bar stuff, the glasses and the mixers and stuff you make C_ocktails with.Last edited by xbox40489; 12-05-2013 at 12:13 AM.
12-05-2013, 12:12 AM #211
I need to do cosmetic stuff, like the screws on the sidepanels(ventilation panels of the k20 ice maker) does anyone know where I can get them cheap?
What size are they anyway?
They can be bought at any hardware store?
17-05-2013, 05:22 AM #212
oh lord i checked this week an ice maker manicotow big one looks so badly maintained and the ice in it is no longer clear.
they are not cubes but like ice with a dent inside but square shaped.
to think they would make a drink with these ice cubes!
17-05-2013, 07:30 PM #213
You would be surprised at what environmental health ignore.
19-05-2013, 12:35 AM #214
You mean the inspectors that come check the hygiene of an establishment?
Well that looks oke but for the poor machine to be working unventilated and in a closed up area is horrible. Specially at night when the place closes. To top it off a fridge is next to the ice machine in the same area.
They never bothered with some ventilation. The ambient temperature must be very high especially in these tropical temperatures.
I cant imagine how hard it will have to work and also how hot it will be when a person goes in that area.
The compressor pushes the hot air out as the ice making process starts.
The fact that the ice is no longer clear must be because the machine has not been services for a while.
19-05-2013, 07:06 PM #215
Ice is supposed to be considered as a food stuff so these "inspectors" should be pulling all the venues/managers on the state of the ice. No ventilation and overheating in a room with an ice machine is leathal as stagnant water in a warm environment will speed up bacteria growth.
19-05-2013, 07:46 PM #216
Well. yeah it is considered as food.
The Machine looked like something like this:
http://www.globeequipment.com/Commer...es/C0830-B948s
But way older model.
The ice chest is full all the time but when the place opens there is ventilation but when it closes down at 5 and for the night it must be closed up in the area. And there will be no other vents open or windows and having 2 appliances with compressors on inside this building would make it quite hot.
I do not even want to think about the insides of this ice machine.
Should be full of scales and limestones.
Outside already it looks rusty. And as I said the ice looks not so clear to me.Last edited by xbox40489; 19-05-2013 at 07:53 PM.
20-05-2013, 07:09 PM #217
Looks like a lot of ones we work on, in theory it should dump all water after every cycle and refill with clean water, works well unless of course it's already stuffed with lime scale and the water filter isn't changed frequently.
22-05-2013, 04:24 AM #218
heheh disaster zone!
22-05-2013, 06:54 PM #219
This is by far the best sign I've seen on an ice machine to date
30-05-2013, 03:48 AM #220
As in killing you with a dash of bacteria?
It is like eating food off a dirty plate that was never washed. It might be dangerous.
05-08-2013, 01:38 AM #221
How is the ice maker scene out there?
By the same place I am working now. Before the 4th of july the ice maker broke down. A big one scottsman i think..
They resorted to buying bags of ice for the party.
Then after they fixed it.
Not sure what was broken did not ask.
06-01-2014, 05:02 AM #222
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
http://www.amazon.com/OTH_LEWISBAGxx...d_bxgy_k_img_y
Update on the icemaker:
I bought a lewis bag and a mallet(wooden hammer).
I needed these tools to sometimes beat the block of ice in the bag loose to be able to have some in my glass.
on the icemaker side. It starts to make thinner pieces of ice and I think I need to set the dial in the back to a bit thicker ice. I have not touched it though since I had thick ice.
It might be something else too that makes the slab of ice thinner then normal.
I need to have it a clean again.
The filter of everpure I have also is in working condition but close to the 10-15 PSI which on the label said needs replacing if it plunges below 10 psi.
I have this filter for quite a while now. But have not used it intensively.
06-01-2014, 09:10 PM #223
as long as the water overflows down the drain when on its harvest cycle then the water pressure drop is irrelevent, when its running ensure the water isnt dripping out the drain plug or spitting into the bin- ensure nozzle head isnt slimed up
26-01-2014, 09:05 PM #224
I poked the drain hole with a plastic straw also tried q-tips.
And it seemed to have cleaned up the stuff between the rubber part and the pvc pipe attached.
Did I mention I bought a wooden mallet to beat the ice back to pieces.
Once you store away the ice blocks in the freezer, the bag of ice becomes one big block of ice.
12-05-2014, 10:00 PM #225
I think the reason they ditches this machines is that the machines harvest cycle for ice is too long.
I have not checked the cycle duration as yet.
But it is more then the 17 min claimed harvest cycle. Probaby around 50 min each cycle.
So I probably need more gas in the compressor?
Let me know.
01-07-2014, 03:32 PM #226
