Thread: total fresh air handler
09-12-2005, 03:50 AM #1
Dear sirs,
I've a design on hand for a total fresh air handler.
#Design paremeters as below:
--The inlet air DB is 29degree celsius,humidity 19g/kgdryair
--the outlet air DB 18 degree celsius,humidity is 6.8g/kgdryair
--air volume is 650m3/h
**The system is going to be designed as one compressor\DX coil (for dehumidifying inlet air)\evaporative condenser\reheating coil\hot gas bypass valve etc.
**the process is inlet air --DX coil(to machine dewpoint 9.88C RH90%)--reheating coil (to 18C,humidity unchanged)--to required space
When the inlet air enthalpy is lower than designed condition,the DX coil load is less ,so the bypass valve open and keep the evap pressure head not down.
my concerns are:
--if the DX coil load is reducing,bypass valve can keep the evap temp constant? if no,how to do?
--if the compressor is constant volume type, the bypass valve can play the role to adjust compressor capacity to meet the DX load?
--reheating coil is parellel to evaporative condenser,the heating capacity is changed while machine dewpoint is varied with the inlet air paremeters,i don't want make the control too complex,is on/off control (EM valve for the coil)reasonable?
--how do you think what the best system for this total fresh air handler?
welcome any comment
best regards
LC-
17-12-2005, 03:29 PM #2
Re: total fresh air handler
use an enthalpy wheel
19-12-2005, 06:39 AM #3
Hi frigidfridgie
I'm not clear how about the efficiency applying enthalpy wheel in so small volume air flow. What type system you recommend?-
Thanks for your reply,you're the first one to answer this. May be it's not a interesting topic-
rgds
LC-I hear...I forget;I see...I remember;I do...I understand
19-12-2005, 09:31 AM #4
Pitcure would help!
Renato
Quick freezing of fresh products
By maxim971 in forum Technical SpeculationsReplies: 12Last Post: 18-09-2009, 11:06 PM -
fresh air heating in cold area
By Lc_shi in forum Air ConditioningReplies: 7Last Post: 14-05-2009, 01:37 AM -
split units with fresh air
By gwilliamson in forum DomesticReplies: 15Last Post: 26-10-2005, 09:57 AM -
Total System Charge
By dallan in forum FundamentalsReplies: 1Last Post: 27-12-2004, 08:18 PM -
Large cold room for fresh produce made of Glass
By allanbaker in forum New TechnologiesReplies: 3Last Post: 11-05-2004, 09:04 PM
