Results 1 to 10 of 10
    Feb 2009
    telford
    2,092
    33
    glycol defrost system
    does anyone know if this is an efficient way to defrost evaporator coils on low temperature applications and which type of glycol is the most efficient if any?
    3,355
    Re: glycol defrost system
    Quote Originally Posted by cadwaladr View Post
    I would say hot gas defrost is efficient if you have more than 1 evaporator.
    Also depends what type of system you have, maybe you could describe what you have in mind!
    Is the glycol question another question?
    Somerset
    69
    4,698
    Hi Cadwaladr.
    Yours is an intriguing question!
    I have never come across glycol being used to defrost evaps.
    I assume that as Ranger may be implying you would use glycol as a heat medium instead of hot gas.
    But as the thermal properties and heat exchanges of the 2 are completely different.
    I would assume there is a good reason why I have not seen it before?
    Obviously as you well know its used widely as a heat barrier in cold store floors or a low temp cooling medium.
    It is also used to cool oil circuits on screws. But I doubt it would work on evaps?
    Nov 2009
    france
    64
    223
    we frequently use MEG at 50% to defrost coolers in large coldstores, temperature is about 35°C. It's spécial coolers, with a second coil imbricated in the main coil. it's a standard for GEA Kuba coolers (some difficults with other brands), we use only for CO2 plants. The hot glycool is provided by heat recovery from the hight side of the cascade, can be from the oil cooling with an intermediate PHE (30% to 50% glycool).
    Somerset
    69
    4,698
    Quote Originally Posted by cricri View Post
    Thanks for the knowledgeable answer cricri.
    Sadly my experience of Co2 systems is nil!
    But seeing as over hear they are still quite specialist it's not so surprising.
    ireland
    1,450
    41
    I've seen a GEA ammonia plant with the same, discharge heats glycol, very very effective and quick. Glycol was also used to cool the chill rooms.
    al
    Somerset
    69
    4,698
    It appears I need to get out more, guys!
    Sadly I seem to be occupied in resurrecting the dead, or at least keeping old plant going nowadays.
    Rather than bringing new (modern) plant into life!
    I have always been a fan of Grenco / Grasso's kit!
    You live and learn.
    Nov 2009
    france
    64
    223
    PICT0042.JPGPICT0043.JPG it looks like that (Luwe coolers)
    Feb 2009
    telford
    2,092
    33
    the reason i ask the question is i look after a system with this type of system ,the issue i have is the owner uses car type antifreeze glycol blue in colour and its heated by electricity very similar to a hot water system a tank with a immersion type heater in it,then its pumped into evaps it seems to evaporate because no major leaks to be found and i suspect we dont have enough to defrost the coils and more storage volume is needed to accomplish the defrost,or is the wrong type of glycol being used?
    Apr 2001
    79
    5,071
    35
    Niagara Blower Company builds a system that sprays glycol directly on the coil to prevent frost:
    http://www.niagarablower.com/nofrost_operation.htm
