Thread: maccy's install
    Oct 2007
    manchester
    5,639
    45
    maccy's install
    greetings gents, im quoting for replacing old dying trane rooftop unis- im hoping to install mitsi splits
    is there any spec of prefered manufacturer or reason why i cant fit ducted units-would prefer to fit cassettes-but i dont think ronald mcdonald would approve-
    by the way -this is a franchise store and the trane gas fired cooling only units have been well butchered.
    Jun 2009
    Lusk , Dublin
    1,115
    Re: maccy's install
    Do Mitsi still do the PMH-P-MYA
    It's a roof top package went up to 55kw i think
    Stu
    Tool's ? check ! Condom's ? check !
    Oct 2007
    manchester
    5,639
    45
    Re: maccy's install
    http://www.mitsubishi-aircon.co.uk/d...%3Fid%3D138345
    no piping-no likey!!!- prob dearer than sticking a vrf in!!
    Apr 2007
    36
    371
    23
    Re: maccy's install
    look pretty sexy...but pricey i bet!
    Oct 2008
    newbury
    1,444
    37
    Re: maccy's install
    They are the biggest bang for the buck after window rattlers..
    Oct 2008
    newbury
    1,444
    37
    Re: maccy's install
    Quote Originally Posted by install monkey View Post
    You will mess up the air flow. Each a/c unit is balanced against the others to give the correct air flow. Installing in celing anything will lose the make up air and affect the air across the counter..
    also my understanding is that every mac's is linked to a central command to monitor the air con and extract.
    It may be a franchise but the building is owned my Macdonalds so be careful about getting authority to work from the landlord not the tenent
    ireland
    1,450
    41
    Re: maccy's install
    There shouldn't be any issues if the existing kit is buggered, i've worked on a good few sites here and the franchisee has the authority to change gear out so long as the dining "experience" is not affected! Keep the air in/out at the kitchen side as per original spec, the seating area can be treated separately.
    al
