    Sep 2011
    Australia
    26
    Refrigerant pressures
    Hi all I am just posting to ask if there are any refrigerant pressure charts out there that will tell me what pressure a certain gas should be running at for eg a cold room on 134a.. I know from going of my pt chart 0 deg is 28psi but im just not sure on what the head pressure should be runnning at? and I know all systems will be different but is there a rough guide to go off? any help would be good thanks
    Sep 2003
    ISRAEL
    66
    4,118
    38
    Re: Refrigerant pressures
    Search google, there is plenty of it on the web.
    Apr 2010
    44
    297
    8
    use the rule of thumb whatever the condenser air on is the temp/pressure of the refrigerant should be 10k higher
    I can fix broke but I cant fix stupid :)
