Thread: Vac Pump Cfm
    Apr 2007
    36
    371
    23
    Vac Pump Cfm
    Hi All,
    I'm buying a vac pump next week, any recommendations?
    looking at something 240v is ok, quiet, fairly fast.
    Im not sure of Cfm rating, i honestly haven't looked at my company one in years!
    Will be used mainly on VRF systems
    J
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Vac Pump Cfm
    Should look for something dual voltage 110/240 and a CFM rating of 8 or above
    But I'm sure opinions will vary
    Stu
    Tool's ? check ! Condom's ? check !
    Apr 2007
    36
    371
    23
    Re: Vac Pump Cfm
    Cheers Mate, I was thinking a 6 or 8 after using one of the install guys pumps
    3,856
    Re: Vac Pump Cfm
    You need bigger hose to get the best out of a vac pump, can only get 0.8cfm down a 1/4" 6ft hose.
    These looked good at the recent trade show.
    http://www.youtube.com/watch?v=zS4JJTfeB5o
    I have a 5cfm yellow jacket pump, does the job but not impressed with it.
    Dec 2004
    U.K
    55
    518
    21
    Re: Vac Pump Cfm
    Why not impressed?
    3,856
    Re: Vac Pump Cfm
    Quote Originally Posted by djbe View Post
    Why not impressed?
    Doesn't like starting in cool weather (advised to keep it in the cab of the van! imagine that in an accident ffs), the check valve to stop oil being sucked out if the power goes off leaks by, it never reaches 50microns even with new oil in with just the gauge on the pump. The rep for YJ at the show didn't seem interested in the issues.
    We have a cheap Dosivac pump that just gets on with the job.
    Think i'll look at JB for my next pump, or possible a Appion TEZ8 but thats a bit big for the suff i work on.
    Apr 2001
    Eden Prairie, MN USA
    5
    Re: Vac Pump Cfm
    The last 5 CFM Yellow Jacket pump was built almost 20 years ago! Try a new 6 CFM and I'm sure you will be happy. Cold starts are NOT a problem with the newer vacuum pumps, and they have features that J/B can't match.
