Results 1 to 2 of 2
Thread: Cool room joint
29-05-2012, 04:46 AM #1
Cool room joint
Hi Guys
Can someone give me a good explanation what to use and how to joint an existing coolroom with a new extension because the panel is diffrent.cheers
29-05-2012, 11:08 AM #2
Re: Cool room joint
Most disimilar joints I have seen are made with either Aluminium
or stainless strips and either self tapped or rivited on.
As long as the joint keeps the continuity of the insulation then the
joint is required to maintain structual integraty but also needs
to be made from somthing the won't react to the environment (rust)
On som sites I have seen the joints made of the same plastic coated
metal the the pannels are made of.
All the best
Rob
