    Apr 2012
    Iraq
    29
    610
    10
    compressor oil quantity
    hi
    did new compressors need adding oil or not
    if its need how much quantity i must added
    Power consists not in being able to strike another but in being able to control oneself when anger arises
    69
    10,484
    Re: compressor oil quantity
    New compressors come with a full charge of oil.
    Feb 2007
    2,477
    38
    Kefah,
    Have you made your mind up yet?
    Adding oil or removing it?
    A couple of questions spring to mind,
    What system are you working on?
    Have you done many compressor changes before?
    May 2012
    1,247
    28
    As others have said it is not possible to give a straight forward
    answer to the question.
    If the system was a correctley sized Airconditioning system then
    no oil would need to be added.
    If the system was a localy designed and installed system using
    components that are generic and off the shelf, then in that situation
    you might need to add oil.
    As a rough rule if you need to fit and oil seperator you need to add oil,
    if you don't fit an oil seperator you might get away without adding oil.
    It just depends on the system and how it is designed.
    If there are hundreds of metres of pipe you will need oil adding.
    All the best
    Rob
    Apr 2012
    Iraq
    29
    610
    10
    i have 2 ton window type compressor
    if its not contain any oil
    how much oil in cc i must add to compressor
    so compressor can work properly
    Apr 2007
    29
    372
    We can't tell you!
    Sometimes if your changing an old compressor they might want to change the oil as the system will be on Mineral oil, and the new compressor on Ester, however they should be finding the right compressors for these jobs. And doing a complete retro-fit.
    If you are replacing a compressor like for like then normally you can get away with it without adding/removing oil. If you need to find out the quantity and type of oil then the manufacturer is who you need to ask.
    Also sometimes there can be a need to change the oil if the manufacturer has stated a certain compressor with a certain oil, example... a Bristol compressor we have recently replaced needed to be drained and filled with lower viscosity oil...
    You need to ask the manufacturer for oil quantity and type..
