Results 1 to 15 of 15
Thread: compressor oil
    Apr 2012
    Iraq
    29
    610
    10
    compressor oil
    hi
    1 question
    when replacing compressor
    some body
    sayed that i must turn on compressor separately before installing to make it throw out its oil outside
    somebody say you must flip up it to throw its oil
    is that true or not
    Power consists not in being able to strike another but in being able to control oneself when anger arises
    Jun 2009
    Lusk , Dublin
    1,120
    Re: compressor oil
    Not .....A compressor is not much use without oil in it.
    It is however good practice to tip the oil out of the old one and measure the amount in it.
    Stu
    Tool's ? check ! Condom's ? check !
    Apr 2012
    Iraq
    29
    610
    10
    Re: compressor oil
    sorry you didnt undestand me
    i mean if i have new compressor
    must i turn on compressor separately before installing to make it throw out its oil outside
    Jun 2009
    Lusk , Dublin
    1,120
    Re: compressor oil
    No I understood you perfectly.
    Don't do it....
    Stu
    Feb 2007
    2,477
    Re: compressor oil
    Ehrm,
    In one word:
    NO.
    (First of all, with modern systems and compressors the oil is hygroscopic and will become acidic when exposed to moisture, as in air. YOU DO NOT WANT TO EXPOSE THE INNARDS OF YOUR NEW COMPRESSOR TO ANY MORE AIR THAN YOU NEED TO. Secondly, but equally important, the oil in your new compressor is the cleanest oil in that system, if any oil needs getting rid of it is whatever dirty oil is left in the system. Also remember that the compressor you are taking out is likely to contain a lot of the oil it originally were supplied with)
    Apr 2012
    Iraq
    29
    610
    10
    Re: compressor oil
    i saw many people flip up new compressor
    when i asked them why you do that
    they answered me they do to make compressor throw out its oil
    i asked why they answered me if didnt do that oil will block ref system
    Apr 2012
    Iraq
    29
    610
    10
    Re: compressor oil
    Quote Originally Posted by The Viking View Post
    so you mean that there is no need to take out any oil from new compressor
    Jun 2009
    Lusk , Dublin
    1,120
    Re: compressor oil
    It sounds like they were avoiding mixing mineral and POE oil's.
    Much easier if you get the right fookin compressor in the first place.
    Stu
    Apr 2012
    Iraq
    29
    610
    10
    Re: compressor oil
    Feb 2007
    2,477
    Re: compressor oil
    Quote Originally Posted by kefah View Post
    Yes, that is what i mean.
    If oil need to be removed it should be removed from the system, always use the cleanest oil possible.
    Another thing for you to think of...
    The only way to remove all the oil from a compressor is to pour it out, by ports or drilled hole but poured out all the same.
    By running the compressor you will only manage to get a small amount out. (And are you sure you really want to run the compressor dry?
    If the reason is as Stu says above, a compatibility issue, then see previous paragraph above...
    May 2010
    ipswich
    26
    Re: compressor oil
    Not true! you can use the vac pump to suck out the oil from the compressor. Although I have only seen it done on belt driven or semi-mermetique compressors. easy, simple oil changes and quick XD
    Somerset
    63
    4,529
    38
    Re: compressor oil
    Jakabus.
    In defence of Viking I think he like most of us are assuming we are talking about small hermetic compressors.
    After all who would suggest flipping the size compressors you are talking about.
    Not those of us which I include Viking with years of experience of working on them.
    If you read the posts again it is not difficult to work out that it's small hermetic comps that are being discussed.
    When jumping in to criticise please take time before doing so.
    Because often the posts have to become quite long before all the relevant facts become clear.
    Grizzly.
    Oct 2007
    manchester
    44
    5,707
    Re: compressor oil
    on a semi hermetic there should be a drain plug to empty the oil out- you can use a vac pump to pull the oil into the system by pulling a vac on the body and have a gaugeline or copper pipe into the oil can- as for vaccing oil out of a compressor with a vac pump-not recommended.
    Quote Originally Posted by jakabus View Post
    May 2010
    ipswich
    26
    Re: compressor oil
    install monkey,
    the vac pump is conected to a container, like a oil seperator. you skrew it in to the compressor oil bung/plug cover thing. well where it goes. saves you unbolting it. the part that goes into the compressor reaches down to the bottom of the sump. no where ells is open on the system ofcorse. we done it so we could give oil changes. let us see what the oil was like and how much was in there.
    Apr 2007
    30
    372
    Re: compressor oil
    That's how i drain um.... none of that vac pump nonsense! Pull a vac on the body and use a hose to pull the oil in from can, or if the compressor is big enough simply pour it it, hose connected to sightglass 1/4 connection and compressor tipped forward. But each to their own...
    Jay
