Thread: Apm 6842
28-05-2012, 03:29 PM #1
Apm 6842
Hi Guys hoping someone can help me on here
No that the warmer weather is approaching i have noticed that the fridge does not seem to be very cold and milk etc is only lasting a couple of days.
I have the Thermostat on number 7 which i believe is the coldest yet nothing really seems to stay cold in this heat.
can anybody try to help me find the problem ie Thermostat etc.
The freezer side all seems to be fine its just the fridge.
We cannot really afford to buy a new fridge freezer at the moment and i am a bit unsure of getting somebody out only to charge me a fortune so it would be really helpfull if i can identifi the problem myself.
If anybody needs any more info i will be happy to assist
John
28-05-2012, 05:22 PM #2
Re: Apm 6842
hi pepps , the number means nothing , what is the temp insaide the fridge? it should be 5 c if its higher you need assistance,
is the compressor running all the time? is there a fan on the unit behined the f/f ? is it running ? are the fins on the unit< behined < the f/f clean? is there good air flow inside the fridge < is it frozen up ? if you cannot see a problem then get a tec in all the best= sedgy ,
28-05-2012, 08:22 PM #3
Re: Apm 6842
replace the thermostat
28-05-2012, 08:47 PM #4
Re: Apm 6842
hi tonto 33,
yes you could be right but what is the temp of the fridge?= sedgy ,
29-05-2012, 09:55 PM #5
Re: Apm 6842
Hi guys thanks for the replies
Ok I need to get a temp gauge to see what the temp is but I can answer the other questions
The fins are clean, the air flow in the fridge is ok
As soon as iopened the fridge I heard something click then start running, the fridge is not frozen up there are drips of water on the back of the fridge
Hope this helps
John
29-05-2012, 10:05 PM #6
Re: Apm 6842
sounds like sog- unbiased opinion!
29-05-2012, 10:26 PM #7
Re: Apm 6842
Sorry newbie to this what is sog?
Also just checked the freezer pipes at back etc have alot of ice etc on them and some of cold bars have lots of frozen ice on them
John
