Thread: MCL Python
27-05-2012, 02:30 PM #1
MCL Python
MCL Pyphon C02 case. Does anyone know of a solution, to the problem of water retention in the base of the cabinets, caused by the force of the evap fans pushing water to the sides? Having problems now in a store as its leaking out of the seams at the sides, has been like this since it was installed over a year ago.
if you cant't fix it don't
27-05-2012, 03:18 PM #2
Re: MCL Python
if dc fans can you slow them down, otherwise- bigger drain stubs of the drip tray?
28-05-2012, 10:18 AM #3
Re: MCL Python
Hi install monkey, you can't alter the drains, but I was thinking of lowering the fan speed as they are DC motors set at 1350 rpm, but that might affect the cabinet temp.
28-05-2012, 08:23 PM #4
Re: MCL Python
hi headgasket, to drain the water you will have to fit a pee trap so the weight of the water can push against the force of the fans, and so drain away = sedgy,
Last edited by sedgy; 28-05-2012 at 08:28 PM. Reason: thread did not print out the full note that IO wrote
