Results 1 to 1 of 1
    Nov 2005
    152
    Your opinions and ideas greatly appreciated for this project.
    Well i have recieved a fridge on R134a ,Fan forced evap
    induced fan condenser. It is a commercial shop fridge.
    It is a project at home, i want to fit schraders and service valves to the system to read pressures at different points at different loads.(yes i am in the trade)
    Any thoughts where you would put them ?
    I'm thinking on the same lines as you have 4 or 5
    different systems in the 1 !
    Tx, cap tube, float type controls.
    the later being hard as it has no bore but maybe, used in conjunction with a reciever it might work.
    A control to isolate different parts of the system (eg)(compressor,fans,flow controls,lights,relays)
    Also maybe a series of sight glasses in the evap and condenser to show the flashing off of the refrigerant.
    ANY IDEAS ?
    2nd year apprentice.
    Yes you may have seen this before. I thought this was a more appropriate place.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
